Results 1 to 4 of 4
Thread: Gas connector pipe
03-26-2019, 04:23 PM #1
Gas connector pipe
Should this gas connector line go through the wall, pipe goes through the sheetrock to gas stove on the other side of wall. Am I being too picky ?
03-26-2019, 05:09 PM #2
Re: Gas connector pipe
Not at all. Hard pipe should go through wall and connector can be installed behind the oven. This is wrong.
G2422.1 3 Listed and labeled appliance connectors in compliance with ANSI Z12.24 and installed in accordance with the manufacturer's installation instructions and located entirely in the same room as the appliance.
03-26-2019, 05:22 PM #3
An approved shutoff must be within the same room within 6ft and not through the wall in another room. Only gas fireplaces have a special dispensation on this rule. You must run 'piping' into the room with the appliance within 6ft. Must have the aforementioned shutoff. You must have a sediment trap unless range, dryer, luminaire or fireplace. Must have ground union or similar joint. Connector can only connect-not pipe.
04-03-2019, 08:07 AM #4
