Thread: Insulation on Crawl space wall
06-14-2013, 08:10 AM #1
I've only seen this type of insulation once. 1960 split home had this insulation on the walls of the crawl. It appears like in was sprayed on put not sure. Also, I think it used to be white and is now black. Any one knows what is call? also any advice on whether or not it should be tested for mold etc. Crawl space was dry at the time of inspection.
I want to thank every in advance for taking the time to reply
06-15-2013, 10:34 AM #2
Re: Insulation on Crawl space wall
Ten years of inspecting and I have never seen it, hope someone provides an answer so I can also learn something new.
06-15-2013, 10:42 AM #3
Me too. Thanks Bill
06-15-2013, 11:30 AM #4
I call it SOS! Sprayed On _hit! We see it all the time in our area and every inspector I know hates it. What I normally see is a sprayed on cellulose product that is gray in color.
06-16-2013, 05:14 AM #5
06-16-2013, 11:18 AM #6
Is the crawl floor concrete or just soil with covering? What is wrong with that spray-on?
06-16-2013, 12:14 PM #7
Floor is dirt. Nothing seem to be wrong.just wanted to know if anyone knew of any issues etc
06-16-2013, 05:32 PM #8
06-17-2013, 05:43 AM #9
We are all seeing more and more closed crawlspaces as well as closed and conditioned. The insulation on the walls however does require a 4 -6 inch gap at the top to permit inspections for unwanted pests and gremlins. There should also be a high quality vapor barrier on grade at the same time and it should be wrapped up the walls and piers a foot or so and sealed.
http://www.jjeffzehnder.com/
06-17-2013, 06:23 AM #10
