Results 1 to 4 of 4
    brianmiller's Avatar
    brianmiller Guest
    Default Propane gas line
    Default Re: Propane gas line
    Quote Originally Posted by brianmiller View Post
    Is copper acceptable for propane gas?
    Yes it is.
    Newer installs use a plastic covered line for underground. That's an older one. Note it in the report.
    Copper is fine for propane. The drip leg however should not be subjected to freezing however. I would also like to see some sort of physical protection for the copper gas line although I would be hard pressed to provide documentation to that effect.
