Results 1 to 13 of 13
Thread: HRV hook up
    Jan 2011
    Mississauga, Canada
    Default HRV hook up
    This was not an actual inspection, but I noticed this in a home a few days ago (see pictures).
    It appears to me that this configuration was incorrect: the two un-insulated connectors are connected to the same return plenum, while the insulated ones are terminated outdoors.
    Mike Rodney
    Ontario, Canada
    Default Re: HRV hook up
    Quote Originally Posted by michael Rodney View Post
    It appears to me that this configuration was incorrect: the two un-insulated connectors are connected to the same return plenum, ...
    I believe the uninsulated ones are air connectors, air connectors have stricter limitations of use than air ducts have.
    Jan 2011
    Mississauga, Canada
    Yes but are they supposed to be connected to the same return plenum...about 10 feet apart?
    Mike Rodney
    Ontario, Canada
    Here is a diagram that might be useful. Of course with this setup, the HRV fan would have to overcome the static pressure of the furnace fan during furnace operation.
    Your setup basically appears to short cycle the air without doing much good.hrvImage.jpg
    The installer thought he would pull some stale air from the furnace return and replace it with fresh, maybe? So somebody ended up paying out a buch of money for something that does a little bit of good maybe on a good day. When the furnace is shut down, it will be a useless waste of electricity. Maybe with a constant flow it will work a bit.
    HRV works best with returns and intakes completely separate from the furnace ducts, IMO, AFAIK.
    That is one of three recommended installation methods recommended by manufacturers.
    Simplified Volume Ventilation
    http://www.venmar.ca/DATA/DOCUMENT/1...ES_HRV_ERV.pdf
    BTW how old is this furnace installation? If its newer the air intake and exhaust for the furnace is now required to be PVC piping and not ABS. But this is why I am asking as to the age of the home/furnace.
    Jan 2011
    Mississauga, Canada
    Its just a rough guess but the house maybe about 10 years old. I really do not know for sure.
    It was not an inspection, I just happen to be there and looked up at the HRV.
    Mike Rodney
    Ontario, Canada
    Okay if thats the age then ABS was the standard. If memory serves me correctly ABS was discontinued for use on furnace 3-4 years ago and new installations or upgrades must now be PVC.
    St. Thomas Ontario, Canada
    636 required on all new installations starting August 1, 2007
    Bryce Jeffrey
    Jeffrey Home Inspection
    St. Thomas, Ontario, Canada
    Thanks, Raymond. I've never seen it done that way.
    (For homes with forced air heating. See illustration at right.)Fresh air and exhaust air flow through the furnace ducts, which simplifies the
    installation.
    The use of bathroom fans and a range hood is suggested to exhaust stale air.
    NOTE: For this type of installation, the
    furnace blower must be running
    when the unit is in operation.
    If using Method 2, make sure the furnace blower operation is synchronized with the unit operation!
    See Section 5
    Quote Originally Posted by Bryce Jeffrey View Post
    Would you care to elaborate what "636" means?
