    cory nystul's Avatar
    cory nystul Guest
    Default sinlge wire in double pull breaker
    Can you have a single wire in a double pull breaker?
    Default Re: sinlge wire in double pull breaker
    Quote Originally Posted by cory nystul View Post
    Yes, but it does need to be correctly identified as non-grounded and the circuit needs its own neutral. I can't tell what the rest of the circuit is by the picture.
    I think Vern misunderstood the wiring you described and the pic is ???.
    There is no rule prohibiting using only one pole of a double pole breaker to power a 120 volt circuit.
    You should try using an old fashioned camera with a flash. You will catch more defects with a flash, I guarantee it.
    cory nystul Guest
    Thanks for tip on a flash. I'll try to remember that next time my camera breaks randomly.
    How "old fashioned"?
    Glass plate?
    Brownie?
    35 mm film?
    Digital?
    Cellphone ("newer" ones have a flash)?
    Glass plate?
    Brownie?
    35 mm film?
    Digital?
    I use an instamatic 110 with flash cube
    But my Polaroid swinger is good when I want to see the picture now.
    Loren Sanders Sr.'s Avatar
    Loren Sanders Sr. Guest
    Rick, I will try to upload a better photo of the panel
    The "yes" was in response to the original question; the rest of the response was to nudge him into looking a little deeper!
