Results 1 to 4 of 4
04-12-2016, 04:00 PM #1
I use the fireplace all the time, there is nothing wrong with it
Sometimes you can only shake your head and walk away...
Similar Threads:Last edited by Alton Darty; 04-12-2016 at 04:03 PM. Reason: wrong photo posted
04-13-2016, 12:32 PM #2
Re: I use the fireplace all the time, there is nothing wrong with it
I will post a shot of last weeks. fire box when I get back in the office. Built in fire suppression.
04-13-2016, 05:18 PM #3
There was bulk water stream down the fire box walls.
Maybe it was installed in a unit with a sub panel.
04-13-2016, 08:06 PM #4
Looks like someone removed the damper and a few firebricks to get a chimney liner down for a wood insert stove that was later removed but the fireplace was never repaired. Some firebricks, parge with Chamber Tech 2000 and a top mounted damper and Bob's your uncle unless there are other issues with it. About a $1,500-2K repair depending upon local market conditions. Look on the bright side: without a pesky throat damper someone can stand up and hand parge the smoke chamber right up to the first flue tile making a smooth transition that reduces the chance of smoke spillage while improving the chamber's dire durability. Level II inspection triggered.
