    Jun 2017
    NJ
    Default TWO prong outlet indicating 'correct' / not indicating an 'open ground'??
    Here is a photo of a TWO prong outlet indicating 'correct' / not indicating an 'open ground'. (Using a 2-3 prong adapter.) How can this be possible? p.s. I'm pretty sure the tab on the adapter was not touching the plate cover screw.
    *Had this posted under 'building envelope' section by mistake
    Default Re: TWO prong outlet indicating 'correct' / not indicating an 'open ground'??
    Main discussion is over here on this thread: http://www.inspectionnews.net/home_i...-grounded.html
    Quote Originally Posted by Ryan Murphy View Post
    Buy a new and better tester.
    Jun 2017
    NJ
    I'm thinking this may have been on a GFCI breaker (in the panel). That would give this result, no?
    Also, aside from the amount of voltage, what more information would a wiggy/voltage tester have been able to provide me over the receptacle tester? I'm believe that I need to get one, I'm just trying to understand what more it will give me and in what situations I should use it.
    No, because there is still no "ground path" for the tester to read, other than the adapter's metal tab touching a grounded metal screw in the cover.
Tags for this Thread
