Results 1 to 4 of 4
    Jun 2020
    FL
    Default When required to replace seething?
    I had this show up in an inspection. The roof seething appears black due to a roof leak. At what point does the seething required to be replaced?
    Default Re: When required to replace seething?
    Did you poke at it with your finger, screw driver, or a probe? If so, what did you find?
    What Jerry said!
    I would be seething too if I forgot to probe the sheathing for damage.
    Curious as to what is on the roof at that spot, to the left of the vent stack - a chimney structure or similar?
    If so, the side of it may also be affected, as well as that truss top chord.
