    Default Seen One of These?
    Default Re: Seen One of These?
    JP: Yes. similar to that. However, I was asking if anyone had actually seen one, you know, like in person . . .
    David Bell's Avatar
    David Bell Guest
    Why not go the extra mile and have a remote coil located in the air handler to cool the house?
    Quote Originally Posted by David Bell View Post
    DB: It makes too much sense.
    On a cold day?
    Better to have it out where the water heater is, and, if in a garage, use it to cool the garage (even on a cold day as it is not as bad as cooling the house you are trying to heat).
    David Bell's Avatar
    David Bell Guest
    We here in southern new england still don't see the amount of heat pumps that the warmer climates do, even with the scroll comps and the lower outdoor temps they can effectivly run at. The thing that contractors are pushing now are the geo thermal heat pumps ( I still call them ground source, but geo thermal sounds more efficient to the customer). The problem around here is the amount of wells needed for a good size house. It can get very expensive.
