    John Stephenson's Avatar
    John Stephenson Guest
    Default Primary drain line material
    Brian E Kelly's Avatar
    Brian E Kelly Guest
    Default Re: Primary drain line material
    From what I see the pipe is well pipe. It is usually used from the pump or foot valve to the holding tank. It is water rated.
    Quote Originally Posted by John Stephenson View Post
    What type of drain line material is this? See arrow. Is it "allowed"?
    I guess a question to that question would be "What is wrong with it"? Keep in mind that you are draining condensate from the HVAC unit. As long as it has the proper traps and does not enter directly into a sanitary drain it should not be a problem.
    Looks like it might be ABS, and that fitting is likely to collect all kinds of gook and crud, causing the condensate line to back up from that point.
    Richard Rushing's Avatar
    Richard Rushing Guest
    I'd be more concerned with the flex gas line entering the housing. This is known to have the potential to cause a fire.
    Put a protective gromet around the wall penetration or repumb to have a rigid line exit the housing where you can then make the flex line connection.
    Rich
