Thread: Some of these things amaze me
04-11-2007, 10:40 PM #1
Look at this one I found today for the RV pad, it might work for cusin eddie
04-12-2007, 08:05 PM #2
Re: Some of these things amaze me
I bet they had a hard time getting the wires through the plumbing fittings...
09-14-2009, 09:05 AM #3
Not too hard if you run the wire through all the fittings and pipe before you glue it.
09-14-2009, 09:11 AM #4
Ben,
Which is, of course, not allowed ...
Of course, being "allowed" does not matter when one is: 1) using plumbing pipe (not "allowed" either); 2) running up into the meter (not "allowed" either); 3) ... I doubt they know or even care was is "allowed" ...
09-14-2009, 10:28 AM #5
A simple question may be: "What is right about this installation?" The list of what is wrong is a whole lot longer, and the only thing right is the use of a proper power outlet / enclosure.
09-14-2009, 07:37 PM #6
Did you turn the valve on to make sure water came out?
