Results 1 to 12 of 12
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Swiss cheese glue lam
    Any thoughts on the number of lags through these glue lams. Makes me hungry, loose like swiss cheese.
    Default Re: Swiss cheese glue lam
    It's undoubtedly engineered.... there should be some plans available or at least there were at one time. Aside from mentioning the buyer chase down the plans there's nothing I'd say.... unless there was a visible problem with it.
    The holes are weak but the bolts are strong, the bolts are strong but the holes are weak.
    Yep, we need an engineer to figure this out.
    I think an engineer already did.
    I doubt all those bolts were placed there for cosmetic reasons, I am sure they were specified to be there, in that staggered spacing.
    I would not worry about it.
    Ron Bibler's Avatar
    Ron Bibler Guest
    It looks like they may have over counter sunk the heads.
    I would point out over drilling of the beams as a foot note.
    any further information required check with plans.
    Santa Rosa California Home Inspection - Exterminating & Thermal Imaging
    Unless you have a Sherman tank collection parked over the top of that beam I would not give it a second thought.
    MS: Very ugly - but hell for stout.
    Why did they do that? Was there something hanging on the other side? It looks open on both sides in the photo.
    Ron Bibler's Avatar
    Ron Bibler Guest
    I think these beams are supporting an upper roof or a half vaulted roof.
    Sep 2009
    Rolla, MO
    GluLams are usually made in standard widths and from your picture the engineer used two beams. The bolts allow the two beams to act as one beam. Unless you see any significant splitting or sagging I would not comment on that beam.
    Richard A Hetzel's Avatar
    Richard A Hetzel Guest
    Washers are sometimes countersunk into glu-lams as shown. Typically, they are not, but the consistency of the depths and the accuracy of the drilling suggests it was part of the design. The number of holes is of no consequence, given their function of "laminating" two glu-lams together so they act as one beam. The precision of the spacing also suggests that it was engineered. I see no reason to make any comment at all.
