Thread: Furnae vent
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Furnae vent
    Does furnace vent have to rise vertically 12 inches prior to making any bends.
    brianmiller's Avatar
    brianmiller Guest
    Default Re: Furnae vent
    yes.
    bm
    Good point.
    Check the manufacturer's specs... that being said, the vent looks very amateurishly installed. My 'radar' would definitely be heightened.
    Jack Murdock's Avatar
    Jack Murdock Guest
    Default Re: Furnace vent
    Matt,
    This is what a vent install looks like when the technician does not own a set of crimpers and has to rely on fittings. At least the Maxitrol regulator is installed properly with a the tower up and a vent limiter installed.
    Jack
    Jack,
    Is there a pic.
    Jack Murdock Guest
    Matt,
    A " pic" of what ? The regulator was in the photo you posted. Sorry if I missed something.
    Jack
    Really? So what do you do if you mount the furnace horizontally?
    Run the vent as specified by the manufacturer, and if not specified, come off the furnace, 90 up vertically for 1 foot minimum, then turn horizontal if needed.
