Thread: Pier Graphic
10-04-2009, 12:43 PM #1
Pier Graphic
I have spent the past hour looking for a decent graphic depicting a residential foundation drilled pier's rebar placement. Does anyone have something like this they would like to share?
10-04-2009, 01:26 PM #2
10-04-2009, 01:27 PM #3
10-05-2009, 03:44 AM #4
Re: Pier Graphic
BJ: I'll attempt to remove the argot block. When one is building a pier and beam foundation one drills holes in the ground, adds rebar, and then fills the holes with concrete. The resulting entities are called piers. I am looking for a graphic depicting the proper placement of the rebar in these drilled piers. I suppose you could also call them augered piers. The IBC does, but no one here ever says "augered".
Something like the picture below, but a line drawing showing the whole hole, if you will.
10-05-2009, 03:35 PM #5
Re: Pier Graphic
Aaron,
It would vary depending on the engineering.
The size of the vertical steel, the number of vertical steel bars, the size of the hoops, the spacing of the hoops from the bottom and the top and each other will be specified by the engineer, which all depends on what is going to be placed on those piers, which also has to do with the number of piers installed.
10-05-2009, 04:29 PM #6
