Thread: Roof flashing and install
10-26-2009, 10:53 AM #1
Does this look correct? I can't even tell what they did here. There is a bunch of sealant in this area. And it looks like they pieced the roof together. Also, correct me if I am wrong but shouldn't the metal flashing go behind the siding?
Thanks,
Ryan
10-26-2009, 12:20 PM #2
Re: Roof flashing and install
Doesn't look right to me either. I would probably have cut the panel completely across and then lapped the material like a shingle. But, I have never installed metal roof, so I could very well be wrong.
Only if you don't want it to leak at that roof/wall connection.
10-26-2009, 12:22 PM #3
Gunnar, what do you think about the flashing? I think it should be under the siding.
10-26-2009, 03:32 PM #4
hey Ryan the flashing should be behind the siding.It looks like a handyman on the liquor!! lol
10-26-2009, 03:42 PM #5
10-26-2009, 08:02 PM #6
In addition to the botched valley and the leaky wall junction, look at where the fasteners are at the eaves. They should only be on the high ridges.
Also, that type of roofing should only be used on sheds and barns, where a few small leaks won't be noticed. Because it will leak.
12-13-2009, 04:01 AM #7
I might not leak if the roof underneath is still good. I've seen this kind detail too much, unfortunately for the home owners. The valley should end on a split panel. This looks like a roof over, a cheap one too. Exposed fastener metal roofing, like this one are marginal as a barn roof much less on a house. My advice is tear it off, along with the roof or roofs underneath and start fresh.
Frank Suchodolski, RRO
12-13-2009, 07:15 PM #8
12-14-2009, 10:02 AM #9
When I see a metal roof or any roof installed with poor workmanship like this I recommend that a certified roofing contractor familiar with this type of installation review the entire roof.
12-14-2009, 10:24 AM #10
If you have a good roofing contractor that you trust, but a roof inspector might give better information for your clients, as roofers tend to look at roofs and think re-roof first ask questions later.
Am I safe to assume you are a roofer. Looks like the Vancouver winter weather has set in and given you a chance to catch up here.
