Results 1 to 11 of 11
Thread: Concealed Vertical Spaces
10-24-2009, 11:46 AM #1
Yesterday I encountered a furdown above a triangular area framed in a corner of a hallway. Below, in the hallway, the area is sheathed with drywall with inset drywall shelves for art display. In the attic, however, there is a hole about 2-1/2 feet deep. Shouldn't this vertical space be firestopped at the ceiling level, or does the waferboard sheathing preclude the need for a ceiling level firestop?
Similar Threads:Last edited by Robert Autrey; 10-24-2009 at 11:49 AM. Reason: Forgot to attach photo.
10-24-2009, 11:52 AM #2
Re: Concealed Vertical Spaces
Similarly, at the same house, the draft stop (or fireblocking) at the vertical chimney chase has been penetrated at two locations. One is a CATV cable that descends from the attic through a hole that appears to have been bored by the home owner in order to mount a flat panel TV above the fireplace opening. The hole is rather large and the code indicates to me that some kind of fitting is needed to provide closure at the gap. The hole seen in the attached photo penetrates the top of the stud wall that forms the face of the fireplace (and one side of the triangular flue chase). Nearby, and directly adjacent to the fireplace flue itself, is a 4-inch flex duct that penetrates the draftstop at the ceiling level. There is also about a 1/2-inch gap at that penetration. Should these penetrations have some type of fitting as seems to be indicate in the code?
10-24-2009, 07:12 PM #3
10-24-2009, 07:14 PM #4
10-26-2009, 09:04 AM #5
In my opinion the furdown above the triangular area framed in a corner of the hallway does have the proper fireblocking.
Now the penetrations where the wires are need sealed.
10-26-2009, 12:33 PM #6
Also, don't ignore the energy losses in the uninsulated walls of those furdowns. A simple solution is to cover the top of the box (with something like plywood or OSB), seal the joints (to reduce air infiltration) and insulate over it.
Bruce Breedlove
www.avaloninspection.com
10-26-2009, 04:54 PM #7
you will also note that most fireplace manufactures require the the fresh air intake opening to be lower than the top of the fire box that one appears to go up the chimney,
10-26-2009, 06:29 PM #8
10-26-2009, 06:42 PM #9
10-27-2009, 11:43 AM #10
10-27-2009, 12:47 PM #11
Correct.
You are allowed to use 1/2" gypsum board, but you are not allowed to use 1/2" structural panel - the structural panel would need to be 3/4" - and structural panel is what is shown, not gypsum board.
Or cover that exposed structural panel with 1/2" drywall, that would work.
