Results 1 to 4 of 4
Thread: peppermint test
10-30-2009, 04:34 AM #1
peppermint test
I was talking to a person the other day about an odor they have in their house. It is a slab on grade. They've had several plumbers out and one of them recommended a peppermint test to check for hidden leaks.
I had never heard of this method of testing for leaks. Do any of you have experience with it? How effective is it?
Testing water supply and more plumbing
10-30-2009, 09:18 AM #2
Re: peppermint test
Chasing odors in waste lines is hard no matter what type of test you do. I have heard of the peppermint test and I have witnessed smoke testing. My town even did smoke testing of the sewers not long ago. That was a sight seeing homes vent pipes smoking!
I would think that if you can't find an odor that is already present then you won't be able to find a peppermint odor either.
10-30-2009, 11:19 AM #3
Re: peppermint test
Don't you know you aren't suppose to eat the mints from the bathroom?
They need a pipe camera to scope for breaches in the pipes. If they really have to, they can have a plumber use test balls and pressurize the system for leaks. Won't locate but will prove the DWV line is tight to a degree.
Bob
10-31-2009, 07:28 PM #4
Re: peppermint test
The "Peppermint Test" will tell if the odor is coming from the dwv system or not. Not where the leak is, if there is one.
