Results 1 to 12 of 12
Thread: Code compliant connector?
11-06-2009, 07:14 PM #1
I am finishing a house for a homeowner (original contractor has gone out of business).
New construction home that has a lot of elecrical issues, and a lot of these connections.
My electrician said he would never use this type of connection, but was not sure it was a code violation.
Any thoughts? Thanks in advance.
11-06-2009, 07:48 PM #2
Re: Code compliant connector?
Not as done, as it was not done per manufacturers instructions & not using the proper crimping tool, plus how was it insulated???
A real hack way of using splice caps is to simply use lineman's pliers to crimp them flat on a splice, a very poor method IMO.
Buchannon (Ideal) specs the use of their C24 Press-Sure-Tool for their brand of splice caps, they may list others but I use that tool.
11-06-2009, 07:59 PM #3
Rollie,
It had a couple of round of tape on it, I pulled it off to see what was there because it is not something I see around here.
Judging from what I have seen, it is safe to say there are no specialty tools being used.
11-06-2009, 09:20 PM #4
11-06-2009, 09:54 PM #5
call for a inspection to get the electrical inspectors opinion, looks like no rough inspection was done..
11-07-2009, 05:35 AM #6
"call for a inspection to get the electrical inspectors opinion"
There are no inspections for each trade, one inspector does it all
11-07-2009, 06:31 AM #7
[quote
quote]
Problem with that ???
11-07-2009, 08:28 AM #8
Ken,
I personally get along with all (4) inspectors in my county. One was an electrician, one was a plumber, one was a framer and the other inspector I'm not sure.
When we call for a complete rough in (framing, plumbing, electrical, mechanical) you can tell who the inspector was from what was written up. I don't think they are doing a poor job, I just think letting them inspect what they know best would make more sense.
11-07-2009, 11:18 AM #9
Chris-
I whole heartedly agree with you on this. I even know some combination residential inspectors who also agree with that line of thought!
I was always told " You can't beat a man at his own trade".
I was curious as to what your reply was going to be.
11-07-2009, 01:16 PM #10
[quote=Richard Pultar;107838]call for a inspection to get the electrical inspectors opinion, looks like no rough inspection was done..[/quote]How can you tell?
11-07-2009, 01:18 PM #11
11-07-2009, 06:09 PM #12
That varies not only from state to state, but within a state from AHJ to AHJ.
An example is South Florida, which has a high population, and where one inspector inspects for one trade (when working for the municipalities), versus up where I am now and one inspector may were many hats, depending on their experience, training, and state certifications, I wear many hats, including, but not limited to: building, mechanical, plumbing, and electrical when I do my code inspections, and I do both residential and commercial (non-residential) inspections. For plan review I am currently limited to building plan review only.
