    RobertSmith's Avatar
    RobertSmith Guest
    Default Saftety/tempered glass
    Does anyone have any idea when safety/tempered glass entered the building codes? I'm trying to figure out if it was required for a 1968 home.
    thanks!
    Rob
    Default Re: Safety/tempered glass
    Quote Originally Posted by RobertSmith View Post
    thanks!
    Rob
    Robert,
    Do a search on that, we had that question asked recently and came up with some relatively applicable answers.
    By the way, it does not really matter in the end when it was "required" as the unsafe aspects of it existed long before it was considered and then inserted into the code.
    'Safety' does not read codes to know when to behave and when to create a problem.
    Default Re: Saftety/tempered glass
    Chuck Lambert's Avatar
    Chuck Lambert Guest
    As JP says safety has no age. My first house was built in 1959 and my current house built 1962 both have the original glass sliders that have safety glass.
    Chuck
    Jun 2007
    The Blacklands Of Texas
    thanks!
    Rob
    When in doubt read the TREC SOP:
    (m) Exterior and interior glazing. The
    inspector shall:
    (2) report as Deficient:
    (C) the absence of safety glass in
    hazardous locations.
    Knowledge is power, but sharing knowledge brings peace!
    www.psinspection.com
    Texas License# 7593
    Philippe Heller's Avatar
    Philippe Heller Guest
    The author of CodeCheck series wrote a good article.
    http://www.codecheck.com/cc/images/SafetyGlazingArticle07.pdf
    Suggestions: We avoid stating a specific date as to when something began to be "required". This implies that you are citing building codes.
    We do say something like "this house was built prior to the requirement for GFCI installation...Recommend upgrade for safety" but we avoid stating exactly when they were required.
