Results 1 to 15 of 15
    Sep 2007
    San Antonio TX
    Default Inspection report writing
    Does anyone know of a course offered or book that exists to teach the proper writing, wording.
    Sometimes I waste to much time trying to describe problem or issue find in home.
    Default Re: Inspection report writing
    "Inspection Basics 2.0" which can be found at the CREIA Online Store under CREIA Educational Materials for 29.95. Plenty of good stuff for not only beginners but many of our old salts, plus some worthy legal advice. California Real Estate Inspection Association - CREIA - Online Store
    Aaron Miller's Avatar
    Aaron Miller Guest
    You might also check into technical writing courses at your local university or community college.
    Aaron
    Richard Stanley's Avatar
    Richard Stanley Guest
    Keep it simple. Write what you see. Including a picture when possible explains a lot and backs up what you are wrting. Did I say keep it simple? I'm guessing you are not an engineer and the people that hire you are probably not expecting one - they just want to know the condition of what they are buying. Are you licensed and practicing yet?
    Quote Originally Posted by Zibby Swieca View Post
    It is not that hard. Just write in simple easy to understand terms. Write in the first person and in a conversations style. In other words, write like you are talking to someone. Richard said it very well; Keep it simple!
    You don't need to fill the report with a bunch of verbiage that describes the attributes or what the procedures for repairing might entail. Just report what you see and what needs to be done. Example: The hall bathroom GFCI is not working properly, it did not trip when I tested it. You should have an electrician repair or replace it as needed. Simple as can be, yet it tells the location, what is wrong and what needs to be done.
    You might want to attend a TAREI meeting or seminar sometime. They usually hold a class on the subject of how to write reports.
    Brian Murphy is a excellent person on the subject if you request of TAREI when he might be holding a class.
    Great way to earn those CEU's also.
    Lewis Capaul's Avatar
    Lewis Capaul Guest
    Here are a couple, I can't vouch for the quality, only that they are being offered and others have seemed to appreciate Bonnie's, I haven't heard anything about ITA's.
    Bonnie Trenga
    The Inspector's Journal Forums
    ITA
    ITA Home Inspection Training Schools - Become a Home Inspector
    And then there's always this:
    Amazon.com: The Elements of Style, Fourth Edition: Books: William Strunk Jr.,E.B. White,Roger Angell
    Cary, North Carolina
    Following the ASHI Standards of Practice is a good way to serve your clients and stay out of trouble. Briefly describe what you see, explain why its a problem (if not self-evident), and recommend repair, monitoring, or evaluation by a qualified contractor.
    You don't need to write War and Peace. Usually two or three brief sentences is sufficient.
    Quote Originally Posted by Bruce Barker View Post
    Would this work then?
    1. The Inspector showed up.
    2. The house should have been dozed years ago.
    3. The inspector went home.
    How was your day? That sums up mine.
    Rules of Reporting; from Inspection Basics 2.0:
    1. Locate – Where is it?
    2. Identify – What is it?
    3. Describe – What is its condition?
    4. Explain – What does this mean?
    5. Recommend – What should be done?
    Lancaster, CA
    Very Nice!
    Jul 2007
    Chicago
    In Texas you must follow Trec.
    Stick to SOP and go from there.
    Some Report software like Home Inspector Pro offers a good TREC template, so get a free trial and learn from the template as a good start.
    Atlanta, Georgia
    North Carolina Licensing board has been pushing DDID for a number of years.
    Describe: the defect and where it is located
    Determine: what is wrong with it
    Implication: What can happen if nothing is done
    Direction: What should be done about it
    It scares me to look back at my old reports and see how much I wrote and how 'rambling' it was. Over the years I've learned you can say much more by writing less.
    Like the others said... basically what?, where?, why it's a problem and what should be done about it. Often times it can be accomplished in one sentence.
    Ex: The kitchen exhaust fan discharges in the attic and should be properly routed outside to prevent excessive moisture above the house.
    Throw a picture and an arrow next to the comment and you're done.
    Jul 2007
    Chicago
    I go with FOG
    Fact
    Opinion
    Guidance
    learned that years ago in school and it has served me well.
