    Apr 2008
    McKinney Texas
    Default Would you write this up ? See photo
    Condenser disconnect in sight of unit, but behind fence (and no gate). You can just see the top of the disconnect on the other side of the fence.
    Default Re: Would you write this up ? See photo
    Not acceptable.
    Same here Gene. Write it up.
    Same here, write it up.... in 'marginal' cases like a bush partially obscuring it you don't have to beat it to death. just state the facts - disconnect boxes are intended to have a clear line of sight for the safety of the people servicing the equipment and this one does not and should. Nobody can argue with the facts when they're presented in an unbiased way.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    No question. Not accessible.
    It's wrong.
    Sep 2009
    Twin Cities, Minnesota
    just out of curiosity: what would you guys say if there was a gate in the fence right there? (you can't see the disconnect, but it's right there.)
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Nolan Kienitz Guest
    Disconnect is supposed to be "in sight". Even if there is a gate for 'easier' access it is still not "in sight".
    Terry Neyedli's Avatar
    Terry Neyedli Guest
    Only for use for those with more than bordinghouse reach.
    Not even if you had a gate, it needs to be within reach of
    the unit to the disconnect.
    Call it out.
    T.Neyedli
    www.alphahomeinspections.ca
    Sep 2007
    Fort Worth Texas
    But not within who's sight?
    Quote Originally Posted by Terry Neyedli View Post
    Call it out.
    T.Neyedli
    Alpha Home Inspections - Port Alberni, BC
    Terry,
    You will need to explain that to me ...
    "it needs to be within reach of the unit to the disconnect"
    You did/do you get that from?
