Thread: hole in sump discharge pipe
12-31-2009, 01:37 PM #1
I found a hole in a sump discharge pipe. This is on a portion of the pipe that is below the check valve. It is about 4-6 inches below the lid/slab level. When the float is lifted and the pump comes on, water can be seen squirting from the hole as shown in the picture. The water just falls back into the sump pit so it does not create an external leak.
Is there a reason that a plumber might have done this intentionally or should the hole be fixed?
12-31-2009, 01:56 PM #2
Re: hole in sump discharge pipe
That hole is supposed to be there. I believe it's to drain water out of the pipe to make life easier for the pump next time it starts up. Something like that.
Ok, now I think it's to let air out when the pump next starts, to avoid "air lock". Anyway, it's supposed to be there.
Last edited by John Arnold; 12-31-2009 at 02:20 PM. Reason: upon further reflection, I mean, research...
12-31-2009, 03:34 PM #3
Thanks John. I had a feeling it was meant to be there.
01-01-2010, 09:56 PM #4
Seen a hole in the floor next to the sump , and it was coming out pretty good, the water table is so high , the basement was waterproofed a few years ago and I think the people put this hole in floor to releive the pressure. Also seen one of his neighbors try to plug the drain in the basement with a plug and it cracked the entire basement floor, a lot of pressure.
01-02-2010, 09:45 AM #5
The hole relieves the pump pressure that can cause fluttering or banging on the check valve.
01-02-2010, 02:08 PM #6
01-04-2010, 10:42 AM #7
Wow! This is a new one for me. I've seen quite a few leaky connections on discharge lines, most with attempted duct tape repairs, but I've yet to see where a "vent" hole had been deliberately drilled. Does anybody call this out in their reports if the vent hole is missing?
01-04-2010, 12:14 PM #8
