07-13-2007, 05:24 PM #1
Secondary drain overflow shut-off
If there is no secondary drain overflow shut-off wired in, do you guys write it up? If you do, as a repair or recommandation?
Thanks,
07-13-2007, 06:05 PM #2
Re: Secondary drain overflow shut-off
Matt,
That depends...
If the secondary drain pan has a drain line, is properly plumbed and is run to a conspicious locations... no. No shut off switch required-- nice to have, but not required.
07-13-2007, 06:16 PM #3
07-13-2007, 06:43 PM #4
07-13-2007, 07:03 PM #5
