    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Cut joists in attic
    There is a vaulted ceiling above this area, and these joists appear to be supportig the drywall ceiling below the area. Is it Ok to cut these in this situation.
    chris mcintyre's Avatar
    chris mcintyre Guest
    Default Re: Cut joists in attic
    NO. I-joist like trusses are sized and designed for each application and any cutting or notching (other than allowed in the specs) must be part of the design.
    From the looks of what you have there I would say that is "sparky framing".
    I second that emotion ...
    I've also got concerns about that horizontal member with the large bearing NOT bearing on anything for most of it. Second and third photos.
    I was looking at that as well. The upper half is anchored to the member whiich is about 10 to 15 inches wide.
    At Least This One Has a Big Ole Scab on it.
    Tom Camp's Avatar
    Tom Camp Guest
    Even though the Truss Joist are apparently only supporting a drywall ceiling, there are approved methods for interrupting a truss joist span. Note the attached photo.
    Tom Camp
    Colorado Springs Home Inspector
    Colorado Springs - Home Inspections, Commercial Inspections, Radon Inspections, Mold Inspections
    Looks like also the drywall is not secured? see gap at bottom!
    Rolland Pruner
    Liverm0ore, Ca
    Oct 2009
    Long Beach, CA
    Also I would ask the builder for any exceptions to the instruction from the factory and report any differance and exception to the factory specification. The future or existing swale or failure will be the builder respondsiblity.
    Fred Sweezer Sr
    1-562-234-2689
    fax 361-5996
    [FONT='Arial','sans-serif']http://www.linkedin.com/in/certifiedhomeinspection [/font]
    www.theLongBeachhomeinspector.com
