07-16-2007, 10:15 AM #1
Height requirement for exterior box
This GFCI controlled outlet was at ground level.
What if any requirements are for the height of the box?
07-16-2007, 10:25 AM #2
Re: Height requirement for exterior box
David - I don't know the answer to your question, but it immediately occurred to me to see where you are from, thinking about snow, for one thing, but you haven't filled out your profile.
07-16-2007, 10:31 AM #3
07-16-2007, 10:42 AM #4
2006 IRC E3801.7 Outdoor outlets. At least one receptacle outlet accessible at grade level and not more than 6 feet, 6 inches above grade, shall be installed outdoors at the front and back of each dwelling unit having direct access to grade.
07-16-2007, 10:54 AM #5
07-16-2007, 10:57 AM #6
07-16-2007, 11:45 AM #7
Not sure what code says about it, but that receptacle looks like lawn mower candy to me....
07-16-2007, 11:51 AM #8
07-16-2007, 03:56 PM #9
If it is buried at all, it must be a direct burial rated box ... which means gasketed cover and no openings (like receptacles) which could allow water in.
If it is 'just above grade' but in a depression area and you see a high water mark around it, I wrote them up as needing to be direct burial/underwater rated.
If it is 'just above grade' and no evidence of water ... there is no 'minimum height' requirement.
