Results 1 to 13 of 13
Thread: Double Tap
03-01-2010, 09:02 PM #1
Double Tap
Have never seen this before. There are obvious double taps at the main lugs in main service panel but what got me was the in line fuses to circiut in garage. Those red round things in lines are actual fuses because they didn't want to run this circuit to the distribution panel in house. Has anyone ever seen this before. I wrote it up to have a electrcian look at it. Just thought you'd all like to see.
03-01-2010, 09:37 PM #2
Re: Double Tap
You sound like you are aware of the codes issues with that installation. I wouldn't write it up to be looked at by anyone. I'd write it to be fixed....period..
Those edison fuses are installed in lamp sockets btw....
I'm not quite understanding why they installed the fuses that way under one lug....do you have a picture how they are terminated just to satisfy my curiousity.
03-02-2010, 08:13 AM #3
Re: Double Tap
Roger, Do you mean where they terminate on other end? They are for all circuits in garage and yes I did ask it be repaired not just looked at.
03-02-2010, 01:04 PM #4
Re: Double Tap
Ok, Tom
I understand now what they are doing.... I confess I've never seen anyone do what you have there ...
Where are the black and red conductors going that look to be # 6's?
03-02-2010, 05:24 PM #5
Re: Double Tap
Good one, Tom! Yes I have seen that before. An electrician buddy told me that trick, fuse in a lamp socket, back in '79.
Of course it is wrong and unsafe.
03-02-2010, 05:32 PM #6
Re: Double Tap
03-02-2010, 06:12 PM #7
03-02-2010, 06:19 PM #8
Re: Double Tap
03-02-2010, 06:33 PM #9
Re: Double Tap
03-02-2010, 07:15 PM #10
Re: Double Tap
03-02-2010, 08:33 PM #11
Re: Double Tap
You could be right upon a closer look it does appear to have a regular base but if the fuse has the rejection threads they had to screw the adapter in first .. anyway was just adding some humor as you know. I'll say this though home inspectors come across stuff I never thought anyone would do ... or I should say hoped they never would do....
03-03-2010, 07:27 AM #12
Re: Double Tap
Roger, The conductors you asked about are to the GFCI breaker/disconnect for a hot tub, you can see the top of box in picture to right.
03-03-2010, 08:35 AM #13
