    Jon mackay's Avatar
    Jon mackay Guest
    Default Cable run in attic
    Any violation running cabling through insulation other than unprofessional?
    How about through the ceiling? I did not notice anything on the other side, there must have been a chase below.
    Default Re: Cable run in attic
    No problem with running the NM cables through the insulation, but a big problem with the insulation being installed downside up (upside down ) and the paper facing being left exposed.
    Should we worry about that paper shoved up against the pipe? Is that a B-vent?
    No need to worry about the paper ... we KNOW it will burn.
    Besides, it is the insulation shoved up against the vent which is the problem (for the vent).
    Jon mackay's Avatar
    Jon mackay Guest
    It is a b vent and not in good shape. It was just a little loose.
    Check out the picture looking up.
