    Anacortes, Washington
    Default Quik Quiz - Square D Black Box
    Found this black box connected to the main conductors and neutral. What is it???
    //Rick
    Rick Bunzel
    WWW.PacCrestInspections.com
    360-588-6956
    Default Re: Quik Quiz - Square D Black Box
    Surge suppressor.
    Rick B.
    Where is your PE?
    Default Re: Quick Quiz - Square D Black Box
    Surge suppressor.
    Installed completely wrong ... as they all are.
    Don't think its a surge suppressor as there was no ground leg. Most surge suppressors I have seen also have a light that says it still working.
    I was thinking some type of noise filter...
    RickH - PE? Professional Engineer???
    Rick Bunzel
    360-588-6956
    Chico,Ca
    Quote Originally Posted by Rick Bunzel View Post
    Protective Equipment.
    Philip's Avatar
    Philip Guest
    When things like this comes up, why not call the manufacturer? Square
    D has a factory in Lexington, KY. I bet a dollar to a donut that with a phone call Square D will tell you exactly what it is and if it is installed correctly.
    Surge suppressors do no need a ground, they simply need the two hot phase legs and the neutral leg, the surge will got to neutral (which is, by the way 'ground').
    Quote Originally Posted by Philip View Post
    Why bother, we have already told you that here.
    It is a surge suppressor and it is not installed correctly.
