Thread: 20 Amp plug
05-29-2010, 02:03 PM #1
20 Amp plug
This one has me scratching my head. Picture shows junction box and outlet in basement directly below electrical panel. The outlet is wired to a 20 Amp breaker, black extension cord with a plug on end comes out of junction box and plugs into outlet which supplies power to outlets upstairs behind entertainment center. Can anyone think of a reason to wire it this way and not just wire the outlets directly to breaker which would have been easier to begin with.
Similar Threads:Last edited by Tom Rees; 05-29-2010 at 06:11 PM.
05-29-2010, 02:29 PM #2
Re: 20 Amp plug
There is no reason other than lack of knowledge and planning for this installation! Also the romex wiring is exposed to physical damage!
05-29-2010, 06:37 PM #3
Re: 20 Amp plug
code violation as you can not use rubber cord in place of permanent wiring
harry homeowner busy at work !
05-29-2010, 07:26 PM #4
Re: 20 Amp plug
Could it be an way to illegally back feed from a generator?
05-30-2010, 05:57 AM #5
Re: 20 Amp plug
There was no generator at property. This is what I can't figure either, why did he need a 20 Amp plug at entertainment center anyway (house is vacant now)?
05-31-2010, 07:41 PM #6
Re: 20 Amp plug
If you have a lot of large equipment, video/audio/movie/etc buff, yeah, the equipment would easily need a 20 amp circuit, maybe even two 20 amp circuits. I've seen even more 20 amp circuits to entrainment centers.
As the others have said, though, it was not done correctly. My guess is that the 'sound guy' installed the receptacles, and while he may be a great 'sound guy' he apparently knew nothing about electrical wiring ... other than 'he needed a 20 amp circuit' there.
