Thread: Sewer lines on exterior wall
06-11-2010, 01:54 PM #1
Is it proper to run sewer lines on the exterior wall of a house? This was done as part of a laundry addition at an older home.
06-11-2010, 03:19 PM #2
Re: Sewer lines on exterior wall
Nope. Not where run exposed.
Looks like you are above 'the freeze line', which is basically I-10, so those would need to be protected from freezing by insulation, heat tape, or both.
Besides being protected from physical damage, sunlight, etc.
06-11-2010, 03:52 PM #3
Does protection mean building a box around it or painting and insulating it? Thanks.
06-11-2010, 06:19 PM #4
Don't know about Texas but in these here parts, painting or building a box around it is not considered proper protection.
Based on your question I will guess these are above grade sewer lines. Above grade or exposed no longer allowed here.
I'll defer ... AD where are you ... help the newbie out.
06-11-2010, 10:20 PM #5
06-15-2010, 06:40 PM #6
