Results 1 to 30 of 30
    Nampa, Idaho
    Default Strange attic insulation?
    I found this stuff/insulation? in an attic of a 40's built home. It was a white powdery material that had the consistency of flour. Almost looks like dry mix drywall mud. I have never seen this type of material before. I am guessing that it contains asbestos.
    WESTMINSTER CO
    Default Re: Strange attic insulation?
    TRENT
    pictures my man
    Jon mackay's Avatar
    Jon mackay Guest
    Was the building constructed with block walls?
    There is a type of insulation that matches your description that is used in block wall cavities.
    I would not assume that it is asbestos containing in your report.
    Nampa, Idaho
    Quote Originally Posted by Jon mackay View Post
    No the house did not have block walls, it was a wood frame structure. I am not stating in the report that it may contain asbestos.
    It looks like the sand in public ashtrays... I've never seen anything like it as insulation. I'd cover it back up and forget I saw it
    Cool Re: Strange attic insulation?
    Most probably fine grain perlite, which is innocuous. Flag it as questionable and recommend analysis.
    Nampa, Idaho
    The stuff was very powdery had the same consistency and texture as flour.
    Philip's Avatar
    Philip Guest
    Then you would know the vapor barrier was wrong. In the photo it looks like rock wool.
    Nampa, Idaho
    Quote Originally Posted by Philip View Post
    The insulation above is "Insulsafe" fiberglass insulation. It's the white powdery stuff below it that I'm talking about.
    Sep 2009
    leonardo, new jersey
    need a better photo, could be vermiculite, we have that in a lot of the shore line bungalow's here in jersey, many built in the 40's
    Joseph Ehrhardt
    Oklahoma
    I am not sure of the name of it but it has allways felt and "itched" like a type of rockwool to me.
    http://www.progressivegardens.com/gr...e/rockwool.gif
    A guess (WAG ??) if its water soluable (what the white mystery powder might be) is borax, boric acid, or other form of disodium octaborate tetrahydrate (DOT).
    Used to control dust mites, cockroaches, silverfish, et al, larder beetles, carpenter ants, and other wood borers, as well as wood decay (and fire resistance). DIY or pro, sometimes ammended with a bait ("sweet and low" or similar) to erradicate other ants.
    Presume the attic space was cleaned of any prior (if any) insulation and treated when replacement insulation of questionable depth/thickness layer was installed.
    As indicated earlier recommend testing sample to determine.
    Nampa, Idaho
    There was about 2 inches of the stuff below loose fill fiberglass. It was not vermiculite. I looked and felt identical to baking flour. I called it out as unidentified material and advised having it tested.
    Philip's Avatar
    Philip Guest
    Where did the first owner of the house work. I have seen some strange stuff used for insulation that was brought home from the factory or foundry. This actually sounds like casting sand from a foundry.
    Daniel Leung's Avatar
    Daniel Leung Guest
    I found this light-weight cellulose insulation material in a over 70 years old attic, which contains some short fibers. There are 2-inches thick light brown cellulose on top of the 2-inches thick white cellulose (finer than the top layer, but not in powder form). The white stuffs turned to white ash after a fire test.
    Is this white cellulose insulation contains asbestos?
    Rod Smith's Avatar
    Rod Smith Guest
    Hard to tell if it Asbestos-containing without spending a couple of dollars and have a sample tested. Personally, I tend to treat ANY unknown material as a hazardous material until I know better!
    South-West Michigan
    Post Re: Strange attic insulation?
    This is just a guess or two, based on the available information and the age of the home. Could it be residue from masonry work that was completed before the insulation was installed? How about dry powder fire extinguishing agent?
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Dec 2009
    Denver, CO
    It looks to me like the rock wool insulation that was common in homes dating back to early 1900's. FWIW
    Camille LaFrance's Avatar
    Camille LaFrance Guest
    [quote=Trent Tarter;134643]I found this stuff/insulation? in an attic of a 40's built home. It was a white powdery material that had the consistency of flour. Almost looks like dry mix drywall mud. I have never seen this type of material before. I am guessing that it contains asbestos.[/
    That insulation looks like the same product that I used years ago for underground pipe insulation. Here is a link to a website that will explain more than I can.DriTherm International Inc.
    Oklahoma
    A bulk sample analysis can tell you if it is ACM and will also tell you what percent it contains.
    Chicago
    I have found the same stuff today, about 2" under fiberglass batts. It might be perlite but it's awfully powdery like flour. 80+ year old home.
    Quote Originally Posted by Mike Lamb View Post
    Looks like you may have come across expanded fine Perlite Liken it more to cornstarch or confectioners sugar.
    possibly perlite & gyp board or plaster decomposed.
    Does it disolve in water? does it float? Scoop some up and weigh it, note the volume. Seems far too much to be Diatamaceous earth, borax, or insecticide.
    see www.perlite.net for some info and photos see if it matches what you saw, felt, etc.
    HTH.
    It's NOT perlite. Looks like sand. Hope the ceiling is well attached to the framing!
    Sep 2009
    Dallas, TX
    It doesn't look like asbestos to me but I would take it to a lab and pay the $25 to find out exactly what it is.
    Jun 2010
    Vancouver
    best to document it and report it and suggest testing if they are concerned. once again asking questions of the home owner is also recommended. covering it up and pretenting it was never seen is just not worth it. your there to do a job but that does not mean you have to know everything. the fact you are planning on following up shows you have a good character! )
    Las Vegas, NV
    Maybe it's granny's ashes? But then again she'd have had to be a large person!
    Beacon Inspection Services
    Like Beacon On Facebook
    South-West Michigan
    OK - so I realize this is an "old" thread. But low-and-behold, a recent inspection on a home built in 1925 has this same insulation. There is a three to four inch layer of fine, white powder covered with about four inches of loose fill cellulose. Has there been any resolution on this?1213.JPG
    www.housesmithe.com
    If you find out what it is, let us know.
    Nampa, Idaho
    Rick, I have found this type of insulation on several older homes over the years. I have come to the conclusion that it's "Fine Perlite" insulation, usually it's about 2-3 inches deep. The stuff I have found looks and feels almost like baking flour or baby powder. If it's fine perlite it's not expected to contain asbestos. Of course there's only one way to be sure and that's to get it tested. Here's a good link for some additional information. www.perlite.net
    Lightbulb Re: Strange attic insulation?
    This looks like perlite insulation.
