Results 1 to 3 of 3
    Jul 2007
    Chicago
    Default Curious about weep screed in this case
    I'm assuming it's not required but.... turn of the century brick foundation walls had been stuccoed (could see lath) but no evidence of weep screed or base flashing. Given the brick as an exterior cladding to begin with, would one be required in this case?
    Default Re: Curious about weep screed in this case
    Quote Originally Posted by Ross Neag View Post
    The more important question is: Why did they use lath?
    Stucco on masonry does not require lath, so ... why did they use lath, was there some masonry missing, cracks they wanted to span with the lath, of ... ???
    Stucco on masonry does not require a weep screed.
    Jul 2007
    Chicago
    Thanks Jerry.
