Results 1 to 12 of 12
Thread: I-Joist Spacing
06-13-2010, 07:27 PM #1
I-Joist Spacing
I'm seeing I-joists spaced at 19" on center. Whats with that? Why not the normal 12, 16 or 24"?
06-13-2010, 07:31 PM #2
06-13-2010, 07:58 PM #3
06-13-2010, 08:39 PM #4
Re: I-Joist Spacing
What James said, plus: We often use roof trusses set at 19.2, it takes the wavy look out of the roof when the sun is at the right angle and you don't have to use clips for the sheathing.
I have never seen floor joist at 19.2" or 24" oc. but I-joist like trusses (roof or floor) are designed by an engineer, so if installed per drawings will meet code. I think that I-joist are a great solution for second story floor systems that span over large first story rooms, sure beats the I-beams and flitch plates we had to use. I-joist, especially longer spans, do have some deflection, so while the 19.2" may be acceptable IMO it is not the best way to keep the dishes from rattling in the china cabinet when you walk across the room.
06-14-2010, 04:21 AM #5
Re: I-Joist Spacing
It's all based on design and load 12",16, 19.2, 24, all work if designed properly, sometimes getting the insulation to cooperate is another thing.
06-14-2010, 06:37 AM #6
Re: I-Joist Spacing
We have used 19.2" spacing for floor trusses. It's a little more efficient and can save some costs on a large building.
06-27-2010, 06:26 PM #7
Re: I-Joist Spacing
I have done 19.2 centers a few times... designers idea not mine. I didn't really care for it. Really doesn't save much time or material. Just a hassle getting 16" wall studs to stack.
Randy Gordon, construction
06-29-2010, 07:22 AM #8
Re: I-Joist Spacing
As an insulation contractor, I hate this..."special order" for fiberglass batts and correct size lightning rods (supports)....so the framing contractor can save a joist or two....and use the little black diamond on their tape measure
06-30-2010, 05:09 AM #9
06-30-2010, 06:48 AM #10
Re: I-Joist Spacing
Where we are it is just a few cents more but the real pain is a contractor that awards you the job and then wants it done tomorrow because he has scheduled drywallers the day after tomorrow...In larger cities 19.2 inch batts probably aren't that big a deal to get. If it is a small job, many times we have used 23" batts and "made them work".
We mainly do blown cellulose both walls and ceiling/attic (because fiberglass is crapola-- IMO) we don't stock fiberglass as a rule.
With construction being as slow as it is now many places aren't even stocking a good supply of standard size and R-value batts. So that also comes into play.
06-30-2010, 07:05 AM #11
Re: I-Joist Spacing
Everyone needs to have this I-Joist pocket guide on their computer or wherever. It is for Weyerhaeuser joist but all brands have similar requirements. I could not upload the file due to the size but this is the link to the document.
http://www.ilevel.com/literature/TJ-9001.pdf
06-30-2010, 09:25 AM #12
Re: I-Joist Spacing
Ditto on what Scott said. Look around on job sites. They are left laying around all the time.
