Results 1 to 15 of 15
    Jason Edwards's Avatar
    Jason Edwards Guest
    Default Lintel Lintels Lintels
    Greetings! I have attached several pics of a window on a home with a corroded lintel. Please note the cracks in masonry work on each side of the lintel.There does not appear to be any sagging. Salvagable with a steel brush, rust reformer and paint? Or not?
    Your thoughts please!
    Jason Edwards Guest
    Default Re: Lintel Lintels Lintels
    A few more pics of the lintel. I believe the flashing was not installed properly. It appears to have been painted at one point, sometime between when we dropped the bomb and the japs surrended.
    chris mcintyre's Avatar
    chris mcintyre Guest
    Quote Originally Posted by Jason Edwards View Post
    Perhaps due to the fact that there is a longer lintel one course above?
    Based on the title of the thread, is there another lintel a few courses up?
    I think so.
    Jul 2007
    Chicago
    No moisture barrier and cracking is caused by expansion of the corroding lintel, but how old is the building Jason?
    Is this area exposed to prevailing weather? Could be wind driven rain has entered the area.
    Also what was formerly above this window, it appears there may have been a canopy? The white caulking above the window and holes drilled on top of the window give the appearance of a canopy, along with paint lines down either side of the window? This former canopy or whatever was attached may have also assisted in the demise.
    Jason Edwards Guest
    The building is about 60 years old. It appears to have been repointed within the past several years. Good eyes Raymond. If you notice the line of sealant approx. 2-3 inches up, that is from a awning/canopy that was removed several years ago. In some of the close ups, you may notice an additional line of sealant much closer to the lintel itself. That was the sealant on the upper portion of the flashing (please see attached pic). The attached pic illustrates how the flashing was installed before I removed it (This pic is of another window next to the window in question). As you can see, it appears to be in a similiar state.
    Jason Edwards Guest
    Interesting point Chris. I assumed that the line of sealant was several inches up was from a awning, but could that be another lintel with weep holes (see the holes?) Interesting, why would another lintel be installed without removing the old one?
    Who knows why or what the reason for what looks like a second lintel. It looks like an after thought, perhaps an attempt to salvage the window. It could also be from a metal awning as you said.
    The lintel at the window is blown and needs replacing, scraping and repaint would not do anything for the parts you can not see in the wall. At 60 years of age what you have found should be expected.
    I agree.
    While the bottom of the lintel looks okay, look how much the expanding rusted top surface as pushed the mortar up above the lintel.
    Time to replace it.
    I don't actually see any weep holes... that could be a contributing factor, and as a continuing factor, would be a good indication of the need for replacement.
    Egbert Jager
    Diamond Home Inspection
    http://www.diamondhomeinspection.ca
    Jason Edwards Guest
    Thanks for your comments everyone. Anyone have any idea how much this may run? I would probably do a total of three windows that all appear to be in the same condition.
    That's not flashing you removed but cheap capping over the brick mould. That's not an original window. Triple tracks came later than the post WWII building boom.Remove rotted brick mould, then assess.No on a secondary lintel. Those are not weeps those are bored holes formerly used to secure a wood brace or support for the former awning.Stress fractures at both sides, possibly due to improper mounting of overly heavy metal awnings and so close to lintel.Structural brick not same as facing brick.Costs depends, maintenance on the lintel, the repair and pointing work? R/R the rotted brick mould, or the unknown damage to replacement window unit frame, wall, etc.?
    It will vary from region to region but is always more than you expect.
    Just a couple of thoughts, it will be impossible to match the brick and mortar so a soldier coarse or jack arch may help hide the repair. Also the wire (in the pic, post #6) is a no no.
    I have heard that $1500 per window is a good ballpark figure, but it all depends on your specific area.
    I'll explain what I'm seeing.
    Original rolled steel window unit, cut back, area filled in (note fill lumber at top), gaps fitted with brickmould, replacement window set in place, then capped with aluminum (upper piece was removed to expose brickmould fitted to opening when replacement window was installed).
    Holes (four round, not lined up with joints) were locations of former fasteners for awning. Formed/bent/ rolled galv or lead is flashing and former steel window frame.
