Results 1 to 26 of 26
    Default Mustard Stains on Shirt
    Today while having lunch in my vehicle in between appointments, I had some mustard drip onto my white Polo shirt.
    This shirt is 100% cotton and I'm not sure about how to remove the stain.
    Should I take it to a dry cleaners or take the risk of doing it myself? If I put bleach on it, should I do so in a ventilated room?
    Your help would be greatly appreciated.
    Default Re: Mustard Stains on Shirt
    Dijon or yellow mustard?
    What does the shirt label recommend?
    Who owns the dry cleaner?
    While you are having your tooth pulled at the semen eleben have a chinese laundry take care of your shirt.
    Step #1: Go buy another shirt.
    Step #2: Go do your inspection.
    Step #3: Ask your wife how to remove the stain, if she does not know (women usually - but not always - know more about these things than men do) then take it to a dry cleaners.
    Step #4: Relegate that shirt to crawlspace/attic duty, rub a little dirt on it and no one will see the stain (they will just think you've been working too hard).
    WESTMINSTER CO
    rick shame on you--always have the newspaper sports page in front of you mustard slob
    cvf
    Club soda will remove most any stain or you could pick up one of those stain pens found at most convienience stores or pharmacies like rite aid or whatever the f their name is.
    Then there is the yellow dye if all else fails.
    Did you give the broker a big hug
    Try hydrogen peroxide and Oxy-clean.
    yellow mustard: place stained area on clean absorbant white towel, mix a solution of half liquid dish soap and half rubbing alcohol, saturate stained area with rubbing alcohol/dish detergent solution (not soap, not automatic dishwasher, no oxy's, bleaches or anti-bacterial agents, if you have fels naptha laundry bar works well with alcohol too).Stain will when first wetted and soaking appear to get darker. Let sit at least 15 minutes. Do not let dry out, rinse with hot water.The alcohol helps to lift the tumeric dye, the dish detergent (surfactant) helps to wet the fibers and lift/carry the media in the water. The alcohol with the water makes the water behave even more "wetter".If the wife has some cheap alcohol based hair spray use after dabbing solution and soaking just before and during rinse phase (also works for removing ball point pen ink).If remaining stain, soak stained area in straight white distilled vinegar, overnight if necessary.Oxy bleach will just set tumeric dye stain, as will ammonia. Bleach will set stain and eat future hole in polo shirt.
    Who cares, a stained work shirt becomes a "painting" shirt for use around the house.
    Hey.....Skin flint.....chuck the shirt after running down to Macy's, Dillards, JC Penny etc and buy a sharp looking new shirt to flash the customers with.
    I know...that is no way to treat money....so wasteful........just throwing the money away.......Hey, what is money for but to enjoy life and not have to worry about it. You earned it....go buy a damn shirt. Gees....Mr. 62 a month.
    Spot Shot spray can carpet cleaner
    Rick, this is not a DIY site, take it to a professional
    Yeah, if you're asking here, you're not qualified.
    BTW, sloppy lunch is an occupational hazard. Play it safe with nuts and celery.
    Georgetown, KY
    I like the sports page idea!
    I would defer to a structural engineer, but that's just me.
    Disgusted and Sad!
    I took the white Polo shirt to what I thought was a reputable dry cleaners. He said he could remove the stain but I did not get it in writing and now my "dream" shirt is ruined. It now has a large gray stain in place of the mustard stain.
    I could have easily dyed the shirt yellow, but now it is going to be difficult to try and make it all gray. Who wants to wear a gray shirt? I'm just devastated.
    Guess I could sell the shirt in a garage sale but with this economy I would never recover my investment.
    My wife is no help. She said all my shirts are just bibs anyway and I should ask for a burger with meat and cheese only.
    Should I contact an attorney or just move on and purchase another one and take my losses. I love her, but she is getting on my nerves.
    Philip's Avatar
    Philip Guest
    I always take my shirt and pants off when I eat in the truck.
    Quote Originally Posted by Philip View Post
    Best idea yet! Hey look, there a school parking lot.
    state of jefferson
    Disgusted and Sad!
    guess you could just purchase a new wife. i hear russia is having a sale
    Leigh Goodman's Avatar
    Leigh Goodman Guest
    Had an uncle who dripped coffee onto his white tee-shirts regularly. His wife added some amount of brewed coffee to the wash cycle and it colored the whole shirt the same as the drip.
    James Foy's Avatar
    James Foy Guest
    Buy all future shirts in the color mustard.
    Quote Originally Posted by James Foy View Post
    Switch to Miracle Whip.
    or How to Buy a Polo Shirt | eHow.com
    James Foy's Avatar
    James Foy Guest
    or perhaps petition your local elected representative to sponsor a stimulus program targeted at the shirt-deficient and condiment-challenged, with special grants for educational centers that provided community based mentoring on condiment application and retention during vehicle manipulation and condiment/vestment intersection avoidance.
    Garland, TX
    R “Studmuffin” H,
    in the future (we all know this will happen to you again) grab that Sharpie or crayon out of your tool belt and scribble above the stain
    “Artwork provided by Your Professional Inspector”
    Any observers will be astonished by you skill level...
    throw the shirt in your pool for 24 hr...get back to us with the results
    Mitchell Toelle's Avatar
    Mitchell Toelle Guest
    Rick,
    "Should I contact an attorney or just move on and purchase another one and take my losses. I love her, but she is getting on my nerves."
    Did you mean purchase another "wife" or "shirt"?
    Maybe you could find others across the country with mustard stains and do a class action suit...probably get a penny each after the lawyers were done with it.
    La$ Vega$, Nevada
    [quote=Rick Hurst;136458]Today while having lunch in my vehicle..., I had some mustard drip onto my white Polo shirt. This shirt is 100% cotton and I'm not sure about how to remove the stain. Your help would be greatly appreciated. rick [/quoted & edited for brevity]
    Rick,
    I find that dribbling a little beer on top of the mustard stain does the trick...poof! No more stain! If you practice...you can get into a rhythm. Might as well start practicing now...the older you get...the more you'll dribble anyway
    Glenn R. Curtis CMI
    La$ Vega$, Nevada
    Inspecting Nevada since 1982
