Results 1 to 11 of 11
Thread: Flex Ducts
08-09-2010, 08:03 AM #1
Flex Ducts
Has anyone heard that flex duct will no longer be used in new construction in the near future? I got this from a HVAC tech yesterday. If yes, what are the reasons? Any info will be helpful.
08-09-2010, 08:28 AM #2
08-09-2010, 08:32 AM #3
Re: Flex Ducts
News to me. Everybody uses flex out here. At least for residential. Probably use metal in commercial.
08-09-2010, 08:37 AM #4
Re: Flex Ducts
I actually did hear that but not sure how long ago or by whom. One of those things that just was kind of "Really, hm"
08-09-2010, 11:35 AM #5
Re: Flex Ducts
Here is a link to that information.
Mitsubishi CITY MULTI® Minisplits.
08-09-2010, 11:58 AM #6
Re: Flex Ducts
huh?
Not sure what this has to do with flex duct . . . .
Flex duct is used extensively in residential AND commercial systems. Even high end HVAC system rely on flex duct to a certain extent. I would be amazed if codes eliminated the use.
The truth is flex duct when installed properly is a very good and useful product.
08-09-2010, 03:13 PM #7
08-10-2010, 06:06 AM #8
Re: Flex Ducts
If you see a lot of flex duct, you may want to check your Code. Length and type of flex duct is limited here. Forget the length 5' or 6' for the most part. Been a while since I read that section. The gray plastic outer sleeve flex duct is limited in use. The silver foil outer sleeve flex duct is Ok for more use. Something about fire/fumes with the gray plastic sleeve.
Hope that confuses the issue more.
08-10-2010, 07:07 AM #9
Re: Flex Ducts
There are 2 different types of 'Flex'- one is a connector and one is a duct.
A flex connector is limited to 14 feet while a flex duct is unlimited.
08-10-2010, 03:59 PM #10
Re: Flex Ducts
08-10-2010, 04:07 PM #11
Re: Flex Ducts
Flex connectors may be insulated but may also be made of thin wired mylar internal tubes with mylar outer wraps that do not meet flame spread requirements for flex duct.
