Results 1 to 3 of 3
    PETER W BENNETT's Avatar
    PETER W BENNETT Guest
    Exclamation Lead Covered Conduit?
    I inspected a 1930's remodel, and found wiring in the crawlspace that covered with a soft/gray material.
    I have never seen this before. Is it lead?
    I recommended a second opinion by a licensed electrician.
    Default Re: Lead Covered Conduit?
    I've never seen lead conduit, but that doesn't mean much. Why would it be a problem?
    They had lead covered wires and cables, but I'd forgotten about them, haven't seen them in 45-50 years when I started helping my Dad re-wire old houses, mostly from knob and tube to NM cable. I was a just a kid then.
