Results 1 to 15 of 15
		Thread: Code Downloads
	09-14-2010, 11:23 PM #1 Code Downloads Code DownloadsGreat website with codes from many places throughout the U.S. You can save them to your computer. Go get 'em.
 bulk.resource.org
 Similar Threads:Department of Redundancy Department
	09-15-2010, 08:05 AM #2 Re: Code Downloads Re: Code DownloadsThanks Gunnar. A fine resource indeed.
	09-15-2010, 04:00 PM #3 Re: Code Downloads Re: Code DownloadsThanks for posting. Can you download the PDF, or does it just load onto your screen? I don't seem to be able to store it.
	09-15-2010, 04:34 PM #4 Re: Code Downloads Re: Code DownloadsThanks Gunnar!
	09-15-2010, 05:25 PM #5 Re: Code Downloads Re: Code DownloadsGunnar, a great big thank you indeed!
 I was able to save the couple I opened by clicking on the 'Save' disk icon and on 'File' then 'Save as' from the menu. Even by right clicking over a code link and 'Save target as'.
	09-15-2010, 05:51 PM #6 Re: Code Downloads Re: Code DownloadsAwesome. It wasn't working in Mozilla for some reason, but I snagged what I wanted via Internet Exploder.
	09-15-2010, 06:20 PM #7 Re: Code Downloads Re: Code DownloadsGunnar,
 I've already got saved down to the CA codes ... did you know that the ca.codes and ca.local links expanded out when clicked on? Cool.
	09-15-2010, 07:55 PM #8 Re: Code Downloads Re: Code DownloadsJust a simple way to navigate thru some of these...
 I use the CA stuff, I'll go thru the .pdf's and select/print range of pages and print to a .pdf driver, while saving to file and making my own smaller .pdf's in an order/way easier to find, than say 1 large file.
 Thanks for the link BTW
	09-15-2010, 09:11 PM #9 Re: Code Downloads Re: Code DownloadsRats, nothing for Kansas.
	09-15-2010, 09:24 PM #10 Re: Code Downloads Re: Code DownloadsThanks Gunnar a great resource. I am not able to open it with Google Chrome.
 Any suggestions
	09-16-2010, 11:09 AM #11 Re: Code Downloads
		Department of Redundancy Department Re: Code Downloads
	09-16-2010, 11:13 AM #12 Re: Code Downloads Re: Code DownloadsDavid,
 Kansas might be using the IRC, IBC, etc. straight from the printer. CA modifies the IRC for some reason. Primarily political, I am sure. You should be able to find out what KA uses and then download something from another state that is the same thing. It would still be the IRC etc.
 Manzoor,
 Weird, because I only use Chrome and it worked just fine. Might try IE or Mozilla Firefox. I would assume there is something going on in your settings.
	09-18-2010, 07:27 AM #13 Re: Code Downloads Re: Code DownloadsI right clicked hit save as target then saved them on my doc. I use IE.
 Thanks I was begining to think that New Mexico didn't have codes. Wrong again. Thanks for this.
	09-18-2010, 07:47 AM #14
	09-18-2010, 08:18 AM #15 Re: Code Downloads Re: Code DownloadsThanks Gunnar!!
