Results 1 to 25 of 25
Thread: Red Ink
    Default Red Ink
    I am curious if any of you use red ink or a way of highlighting defects when writing your reports.
    Have been doing the red ink thing for quite some time because it brings attention to those items in need of repair.
    Of course, the RE agents hate it when they see one but the clients like it.
    Any opinions?
    Rick H.
    Corpus Christi, TX
    Default Re: Red Ink
    I use bullets. I add yellow when it's also an issue of safety that should be repaired irrespective of who is living there.
    - Paul Fix
    Colorado Springs, CO
    Default Re: Red Ink
    Red doesn't show up very well in Black & White. On the rare occassions that I actually print a report (instead of e-mailing it) I print it on my laser printer in B&W. So, no, I don't highlight anything in red.
    Bruce Breedlove
    www.avaloninspection.com
    Default Re: Red Ink
    Not just red ink, but Bold & Red really grabs your attention.
    I use it sparingly, typically for safety issues or grossly deficient items. If you use it too much, it loses its purpose.
    Dom.
    The Treasure Coast
    Default Re: Red Ink
    I don't bold or red ink anything in my reports. As 95% of them are E mailed, I could easily do it, but, to me, it is up to my Client to determine what is important to them. I may emphasize certain things at an inspection, and in some cases, most commonly when a Realtor attempts to trivialize what I say or try to tell my Client what is major or minor, I will repeat it and go into great detail about the matter.
    www.magnuminspections.com
    Default Re: Red Ink
    I don't use red ink in my reports. Since many of the reports get faxed back and forth between client/agent and agent/agent, the color doesn't show up (or photos for that matter).
    I have no other reason for not using red, other than it would involve more "clicks" when I'm getting the report together. I want my client to read the entire report, not just look for the colored text.
    JF
    Default Re: Red Ink
    I did not use colors as they did not show up on copies or faxed reports, likewise, bold is lost in some faxes, thus, I used ALL CAPS for those items.
    Default Re: Red Ink
    Sorry, while I understand trying to be considerate of all parties, I'm not going to dumb-down my report just in case someone wants to fax it across town. I write the report for the client, and if the color change or bold typeface is lost on the other end of some future fax, so be it. The client is the one person for whom the font change or colored text is included. (And that is only 1 or 2 "altered" words in, maybe, 25% of the reports.)
    Besides, nowadays, most multi-paged reports are emailed around town, not faxed.
    Using the fax analogy would dictate that no photos are included either, because they don't transmit at all. (Well, they do transmit, just as large blocks of black and gray.)
    Just my .02 cents, and to each his own, of course. What works for one may not work for others.
    Dom.
    Default Re: Red Ink
    One size does not fit all.
    Bruce Breedlove
    Ezra Malernee's Avatar
    Ezra Malernee Guest
    Default Re: Red Ink
    I use red for Defective and Safety items in the body of the report and the summary pages along with color photos. Reports are emailed and a hard copy sent out later. No complaints yet by clients, agents are something else.
    Ezra Malernee
    Canton, Ohio
    Default Re: Red Ink
    Nothing, though BEATS ALL CAPS TO BRINGS ONE'S ATTENTION TO A PROBLEM you want to bring their attention to.
    Dom, just something to consider FOR YOUR CLIENT'S BENEFIT.
    Default Re: Red Ink
    Sorry, Jerry. I refuse to use all caps. It bugs the hell out me trying to read paragraphs of all caps. (Kind of like some of your posts... )
    BUT THANKS FOR THE SUGGESTION.
    Default Re: Red Ink
    There, see? It wasn't so bad after all.
    Default Re: Red Ink
    So what I'm getting from everyone is that BLUE would be more appropriate.
    Default Re: Red Ink
    I use Blue and Red for different purposes, just to set apart recommendations about maintenance is blue and some items in red. I deliver the report directly to 99% of my clients via email, so faxing limitations are not something I consider. If I know the client must have a copy via fax, then I might make a few extra verbal explanations, but even without the different color text, the report will convey all the needed information, it might be little harder to read, but all the information is still there.
    I never use all caps, but italics, underline and bold are all possibilities when appropriate.
    Jim
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: Red Ink
    When I'm typing an item on my report, I use the F9 key in a macro to auto type:
    "In Need of Repair"
    At the end of the item requiring attention.
    Nampa, Idaho
    Smile Re: Red Ink
    Rick, I used to use red arrows or circles. The web-based report system that I use allows me to use different colors. I now use yellow or blue arrows depending on what shows up best on the photo. This seems to not scare people as much, but still draws attention to the item.
    Jeff Knight's Avatar
    Jeff Knight Guest
    Default Re: Red Ink
    Remember that about 8% of males with European origins are color blind and about 1% of females are. The most common color blindness (99% of the cases) are color blind to red and green. I recommend bolding and underlining text instead of messing with the colors to avoid the problems with people that are color blind.
    Jeff
    Default Re: Red Ink
    So I guess using the term, "POS" throughout the report is not recommended.
    Don't you just wish sometimes you just say it like it is?
    Wink Re: Red Ink
    I will sprinkle in the word "death" every so often. For example...."furnace flue pipe blocked with deteriorated chimney debris (death hazard - repairs needed)". I find it really grabs their attention .
    Jeff Knight Guest
    Default Re: Red Ink
    I also have heard many times from home inspectors or teachers-for-home inspectors to not be an "alarmist"....my opinion (as a consumer) is that you should be an "alarmist" if it is an "alarming" issue. I am paying you to help not only discover what is wrong in the house I am buying, but also to help me evaluate what things I should be most concerned about....I may be a newlywed couple that knows squat about homes and I am depending on your expertise to help me out... and I could gives a rat's ,you know what, about whether the agent thinks the inspector is being an "alarmist".
    Default Re: Red Ink
    Fot the last few months, I feel like I'm on the front of the firetruck truck revving up the sirens.
    Is that the firetruck I said needs to be parked out front?
    Default Re: Red Ink
    YES SIR IT IS
    And bringing up the rear are the paramedics and I believe I see a hearse coming too.
    Default Re: Red Ink
    For my old "surviving spouse" and their just deceased partner, no doubt.
    Default Re: Red Ink
    I remember one magical time (which I repeated several times afterward) wherein a builder asked, after I pointed out some serious design flaws - which were also against code - in the swimming pool of a very expensive new house, "What's that worst that could happen?"
    (Never, never, and I repeat - never - ask a home inspector "what's the worst that can happen". )
    By the time I was done explaining what's the worst that could happen, there were *7* dead people in the pool, each progressively died trying to save the previous one(s).
    The look on my client's faces was priceless, but the look on the builder's face was 'a Kodak moment'.
