Results 1 to 11 of 11
Thread: Scissor joist
    Fuquay Varina, NC
    Question Scissor joist
    This home was built in 05. The back wall in the crawl space has a knee wall and then a sill for the joist. Does the sill need strapped to the knee wall top plate?
    The joist sit on the sill and has one toe nail in it. How are they suppose to be secured?
    Does the joist sitting on the top plate spanned between two studs need support under it. It is a two storey home?
    I appreciate any quick replies because I have to get this off first thing in the morning. Thanks in advance.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Fuquay Varina, NC
    Default Re: Scissor joist
    Opps forgot the pictures
    Any chance the exterior sheathing is nailed off properly to tie everything together laterally?
    Fuquay Varina, NC
    I don't know the name of the sheathing but its those 4x8 panels that are about 1/8 thick. There water repellent. Don't remember what they are made of put are very flimsy. As far as being nailed correctly I doubt it but can't be sure.
    Got a picture of the outside of the house?
    Fuquay Varina, NC
    Here they are.
    Martin lehman's Avatar
    Martin lehman Guest
    I don't believe the joists need support directly beneath them, as there is a double top plate installed.
    As far as nailing goes, I am unsure for trusess, but conventional framing is 3 8d nails toe nailed to the top plate.
    There would not be any strapping here in my area. It has been about four years since I did any framing, but I know we wouldn't have back then. It may have changed. Then again, we're definately not in a hurricane zone, or even a high wind zone.
    Fuquay Varina, NC
    Would a single nail be sufficient for fastening?
    Martin lehman Guest
    You sould probably try and look up the manu. specs.
    I'll bet they require one on each side of the flange, for a total of two.
    Utah
    If there are two stories above the wall it should be framed with 2x6 studs or 2x4 at 12" O.C.
