Results 1 to 4 of 4
    so so, California
    Default yone using the Extech M210 pocket moisture meter?
    If you have this, can you explain the scale when the meter is in "building material" mode? 0 - 2.4?
    Jun 2010
    Vancouver
    Default Re: yone using the Extech M210 pocket moisture meter?
    maybe you should check the manuel or check with the manufacture and see if they can send you an operational manuel. that would save you next time when you have a problem with readings.
    Sep 2007
    Fredericksburg, VA
    User Manual available to download at: http://www.testequipmentdepot.com/ex...dity/mo100.htm
    Stu, Fredericksburg VA
    so so, California
    Did that...i'm looking for someone who can explain what is the reason the moisture level only goes to 2.4 not 100%
