Results 1 to 11 of 11
    Default worst ac disconnect
    Worse than no disconnect at all, in a way, because there isn't room to open the cover far enough to use the freakin disconnect!
    Default Re: worst ac disconnect
    You sure are picky John.
    I know.
    Here's what it looks like when opened fully.
    so so, California
    How bout this disco?
    Jul 2010
    Northeastern Illinois area
    The positive thing here is that it looks like the installer left a tube of caulk just in case a refrigerant line developed a leak...
    Dec 2009
    Florida
    Was there a sticker from the electrical inspector for this installation? I'll bet not. However, I had a discussion with an inspector once about mechanical protection for the wiring to a HVAC unit. He said although it was recognized as an issue and required in commercial installations---it was not required in residential installations. I asked him "Do you mean that the wiring can get damaged in commercial installations---but never in a residential installation?" No answer.....
    Rich
    Was there a sticker from the electrical inspector for this installation? I'll bet not...
    Actually, there was a final inspection sticker from the city on the panel.
    This is new construction.
    The receptacle outlets in the garage and at the bar sink did not have GFCI protection.
    There were AFCI breakers only for the bedrooms, even though we're under 2008 NEC now. There was over-fusing in the panel.
    The water service line appeared to be the sole system ground.
    Etc, etc.
    Hmmm. Maybe I should have said "worst ac disconnect placement".
    Ridgewood, NJ
    John, how's the clearances to the wall and the fence, as far as the condenser's concerned?
    Yep, pretty stupid placement. It's actually against code to have it where you have to contact the unit in order to operate the disco due to electrical shock issues.
    Usually not that big a deal to slide the whole unit out a few more inches from the wall. There should be enough play in the connections to allow for this. I've moved these things a few feet in the past when a deck was added.
    877-466-8504
    Mounting the disconnect on the separate structure opens up a whole other can of worms, esp under 2008.
