Results 1 to 4 of 4
Thread: Ejector pump
01-14-2011, 07:51 AM #1
Ejector pump
This is for a wet bar. Is a check valve required and does that coupling below the shut off function as a check or simple a coupling.
01-14-2011, 08:01 AM #2
Re: Ejector pump
Not sure if a check valve is required but that rubber coupling/connector doesn't look like a check valve to me.
01-14-2011, 08:46 AM #3
Re: Ejector pump
Check valve could be intergral to the pump.
01-14-2011, 09:30 AM #4
Re: Ejector pump
a backwater or check valve required before the gate or ball valve.
