Thread: InspectVue problems
01-26-2011, 01:19 PM #1
InspectVue problems
Does anyone have or know of someone that can convert the Version 5 library back to work in version 4 or another program that is comparable to InspectVue that I can switch to?
01-26-2011, 05:57 PM #2
Re: InspectVue problems
I converted to version 5, but always kept my version 4 on the computer, since 5 never seemed to work right. I've been using 4 all the time.
01-30-2011, 02:34 PM #3
Peter do you have a backup copy of your IV 4 Library and do you sill have IV 4 installed on your computer? If so just restore the copy of the library. If not check out windows explorer on your hard drive to see if you still have IV 4 it should be under program data, IV 4 and check to see if you have master library file there. I didn't remove my library in IV 4 when 5 came out just added it to my machine.
Paul
01-30-2011, 03:34 PM #4
HI Paul!!
01-31-2011, 01:51 PM #5
Peter,
Are you looking for a solution that runs on a handheld device so you can collect the data as you are walking around doing your inspection ?
01-31-2011, 03:33 PM #6
