    Default plant that thing
    picture says enough
    David Bell's Avatar
    David Bell Guest
    Default Re: plant that thing
    Must be a ground source heat pump!
    Is that inset dk gray square above housing the disconnect too?
    Could you determine how that stone was installed? One inch air gap? Manufactured stone or real? Looks real but its hard to tell from a picture.
    Any signs of leaks at the baseboards or walls?
    www.BAKingHomeInspections.com
    Yes, disconnect embedded in the stone veneer.
    Water intrusion issues highly likely with this lick 'em and stick 'em veneer. No flashings visible at sills that slope back towards the house. Only a bit of caulk.
    Terry Clayton's Avatar
    Terry Clayton Guest
    Nice Catch on the DK there are some serious issues with this install how old was the unit, looks kind of new.
    Utah
    Quote Originally Posted by David Bell View Post
    My first though as well, you beat me to it.
