Results 1 to 4 of 4
Thread: Shower pan leaking
02-17-2011, 09:31 PM #1
Shower pan leaking
Water under the tile in the bathroom and on the backside, was under the carpet. No visible indications until you stepped on the carpet which was in the way back of a closet. Could have easily missed this one.
Similar Threads:Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
02-18-2011, 05:39 AM #2
Re: Shower pan leaking
Marc
You gotta get a new camera, the color on that one is WAY OFF.
02-18-2011, 10:17 AM #3
Most tile showers around here are on crawlspace houses so you can see the leaks above the floor insulation. Most of them leak.
Was that one on a slab?
www.BAKingHomeInspections.com
02-18-2011, 08:01 PM #4
