Results 1 to 11 of 11
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Flashin caps, not needed?
    East Bridgewater, MA
    Wink Re: Flashin caps, not needed?
    Would you agree that flashing caps are not needed on top of the casement trim ?
    Hello Jeff,
    The windows may be a self-flashing type, in which case your report should have a caveat for risk management. However the top trim boards should still have z-flashing.
    Bob Mulloy
    Default Re: Flashin caps, not needed?
    Quote Originally Posted by Clay E White View Post
    Z-flashing above the trim boards required? Please provide reference. I never write that up -- doesn't mean I'm right but I certainly haven't been noting the lack of the Z.
    Observation: Metal Z-shaped flashing is missing between the intersection of a horizontal trim board above a window and the adjacent siding.
    Analysis: Metal z-flashing should be present above all horizontal trim boards to prevent water infiltration. The flashing should extend under the siding and then downward with a right angle bend over the top edge of the wood trim, and a final right angle bend over the face of the trim board. When z-flashing is missing, there is a risk of water infiltration, concealed damage, decay, and mold and pest infestation. Repair is needed.
    Recommendation: I advise that you hire a carpenter to install metal z-flashing wherever missing.
    David Banks's Avatar
    David Banks Guest
    I like that Bob. Mind if I use it?
    Bob, great verbiage.....what's your reference in code , though, to support your position?
    Clay,
    Things like that don't need support from code or not code, they are "common sense" and *used to be* "good construction practice".
    Think like water, ask yourself 'Can I get in there?', if 'yes', it needs a flashing, or a better flashing, or whatever it is you are seeing/not seeing.
    gainesville fl
    For some reason In this area I think the alphabet stopped at Y because there is not much Z flashing installed, I write it up as being done improperly and that the caulk should be monitored until a proper flashing can be installed.
    Jerry, do they use much Z over on the coast or just caulk.
    Quote Originally Posted by bruce m graham III View Post
    I was in Gainesville for 20 years, from 1967 to 1987, 'Z' flashing was almost always used back then.
    I think it's more of the builders now thinking 'I can save 50 bucks per house, and by the time a leak is discovered, I'm way out of the picture.', but they are not aware of Chapter 95.
    From what little of that I've looked at, it's hit or miss here, I think mostly depending on age of the house. Older ones were more often done correctly, newer ones more not.
    To be truthful, I don't remember is the house we bought a year and a half ago here, built in 1978, has 'Z' flashing or not - guess I'll need to look and see.
    Corpus Christi, TX
    You should have hired an inspector.
    - Paul Fix
    Quote Originally Posted by Thom Walker View Post
    I did.
    But, like most buyers, I don't remember everything which was discussed.
    Don Matthews's Avatar
    Don Matthews Guest
    Talking Re: Flashin caps, not needed?
    Up here in the North, the AHJ will fail a house during the dry-in inspection if he doesn't find Z-flashing above the windows. The only windows I am familiar with that have the factory applied Z-flashing are the ones that are metal framed. It is visible above the window even after the trim boards are applied.
    Be my guest, that is why I posted the text.
