Thread: Pushmatic Spilt Buss?
03-15-2011, 04:21 PM #1
Am I looking at a split-buss panel here?
Can't read the labeling, and I'm not familiar with the panel...
03-15-2011, 05:48 PM #2
Re: Pushmatic Spilt Buss?
No, this is a spilt buss
03-16-2011, 02:37 AM #3
Anyone?
03-16-2011, 03:59 AM #4
Split Main Panel.
Last edited by Joseph Hagarty; 03-16-2011 at 04:03 AM. Reason: reviewed with enlarged photos
03-16-2011, 04:02 AM #5
Upon further review... (enlarged 1st & 2nd photo)
Panel is a Split Main Panel.
03-16-2011, 07:38 AM #6
Thanks!
Just to be sure I have this correct:
1) Configuration is as shown on this section of the panel labeling (attached below).
2) The beakers above the the "MAIN" breaker are always energized.
3) The breakers below the MAIN are set up as "lighting section", and are controlled by the MAIN breaker.
4) Six throws to disconnect.
03-16-2011, 12:37 PM #7
Correct..
03-16-2011, 12:53 PM #8
This is a pushmatic I found a few years back. The only one I have every found.
Hope this helps
03-16-2011, 01:39 PM #9
Thanks again to you both.
