Results 1 to 11 of 11
    Default I don't get it....
    Came across this outlet today and I can't wrap my head around it. My 3-prong tester initially gave a reading of the two outer lights (hot/grd reverse) which seems virtually impossible so I investigated further with the following findings:
    Default Re: I don't get it....
    That is why those 3 light testers are not all that great!! Looks like the ground is Hot. If it was a bootleg ground it would show as grounded, I think....
    Both testers are showing the same thing: hot/ground reversed.
    Unusual, yes, but not unheard of (which is why it checks for that).
    I believe the 4th photo is showing correct wiring.
    Yes... that's what was so weird. When I pulled the outlet off the metal box it read okay. Also, it wasn't gnd/hot reverse at the outlet. The wires coming/going were properly installed (white-silver, black-gold + ground).
    Also... how would a hot/grd reverse even be possible? Wouldn't it just instantly short?
    South-West Michigan
    Post Re: I don't get it....
    My guess is that outlet is not where the problem is. Lurking in the shadows is a junction box, light switch, or other fixture that is mis-wired.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    George Wells's Avatar
    George Wells Guest
    The problem is that the testers you are using have very high input impedance. Use a low input impedance solenoid tester such as a Wiggy. You'll get consistently reliable results.
    Instructions for using a Wiggy to do basic electrical tests:
    It's a Wiggy Wiggy World
    WESTMINSTER CO
    JP
    please explain your post. the last picture shows a good circuit.
    thanks
    cvf
    JP
    Charlie,
    I was referring to this:
    ... and the first 3 photos ... which show a reversed hot/ground wired receptacle outlet.
    Matt said: "My 3-prong tester initially gave a reading of the two outer lights (hot/grd reverse)", and the last photo shows something else, so I went with what he said "My 3-prong tester initially gave ... of the two outer lights ... ".
    JP
    thanks
    cvf
    I agree. My post was refering to this one.
    WESTMINSTER CO
    THANKS JP
