Results 1 to 32 of 32
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Any idea the intent.
    Was this an attemp to seal cracks in a foundation wall. House built in 06. House is located on a hillside and this is the utility room with a driveway above the area.
    Default Re: Any idea the intent.
    I think that you're correct - it was an attempt.
    LOL. Looks like a 1/5 of jack and an account at home depot
    WESTMINSTER CO
    matt
    are you sure that house was built in 2006?
    that looks like a large copper pipe--and i know at the cost of copper these days--the builder didn't install that
    cvf
    James Duffin's Avatar
    James Duffin Guest
    Are the cracks on the low side of the hill? Maybe the house has hill creep?
    Sep 2009
    Dallas, TX
    Nice job. Looks professional. Seller disclosure: "Built-in Basement Coat Rack".
    I think Matthew hit the nail on the head!!
    Not an uncommon repair method for concrete foundation repair. Looks like it could be polyurethane as opposed to epoxy.
    Looks like it's time to call in "John".
    He's a bit foul mouthed, but he knows his "chitt".
    Andy Bailey's Avatar
    Andy Bailey Guest
    I love how they left the tubes from the cans of great stuff in the wall to better show exactly how many cans they sprayed in the cracks.
    The house was built in 07 not 06. She's a beaut clark.
    Agreed,
    Check out epoxy or injected resin wall repairs. I think Simpson carries a line. The remaining injection nozzles are the clue here. From what I understand that is actually considered a structural repair for concrete walls.
    Adhesives ~ Simpson Strong-Tie Anchor Systems®
    Sandie Hastings's Avatar
    Sandie Hastings Guest
    matt
    cvf
    That copper pipe services the fire sprinkler system.
    This type of repair is always for non structural cracks which leak. Very common repair method up here.
    WESTMINSTER CO
    SANDIE
    wow how did you know that. did i miss that in post.
    thanks
    cvf
    WESTMINSTER CO
    sandie
    i didn't open that last picture, or i would have known that--brain fart over here
    cvf
    The copper line was also for the water line, ran the length of the home. Maybe that is why the bank owns it now
    Mat,Even with the limited information you have provided photographically and description, this is potentially and likely to be a "mine field" "pandora's box" situation. Most especially with an as-is REO.A visual cursory examination likely insufficient and at best a hypothosis. Site and plans review, core sampling both geologically and made structures, destructive testing, calculations, etc. beyond the scope of HI and frankly most structural engineers not dually qualified in geo.Tread carefully in your reporting strong language for geo-technical and SE.OW vehicle travel proximity, movement, a host of issues/causes/damages/failures possible. UnKwn if orignal site was properly surveyed, analyized, engineered, designed, and executed, in the first place.
    HG, agree and all front, built into a hillside. Recommended further evaluation to cover my butt.
    David Valley's Avatar
    David Valley Guest
    Looks like a typical application to seal cracks in the foundation to prevent seepage. I see this type of application several times a year.
    I simply advise my Buyers to obtain the paperwork for this work to see if the guarantee (from leaks) is transferable.
    Aug 2009
    Michigan
    Yes it's a foundation crack repair. Here is a link to one product so you know what it is. Foundation Crack Repair Products
    Randy Gordon, construction
    If there is any movement of the house there should be other clues, cracks on opposing walls, non vertical or bowed walls, corner cracks.
    As pictured, although not at all necessarily; however not what was being discussed, Mat's area not sediment flatlands note his location. Re-read original description & Mat's follow-up posts and note pattern at uphill intersecting walls!
    Follow the colors, cracks and voids and junctions, esp. rust.
    Yes I noted house constructed on slope. Rust could be from form ties, iron water. Still - regardless, as noted I would be looking for other clues.
    Keep looking Raymond, 3/4 of your "clues" are pictured as are so many "clues" provided that are "beyond you"; however, after your most recent I'm giving up on you.
    Mat "gets it" and "got it".
    Watson, don't over complicate something you obviously don't understand. KISS.
    LOL, I have KISS'd it for you SS Raymond. Fortunately Mat isn't S or S.
    The issues are frankly, over your head.
    Nice of you to speak for Matt.
    How many times do I have to flush before you go away?
    Nice profile by the way!
    Joao Vieira's Avatar
    Joao Vieira Guest
    Again a good cyber social event goes down the tubes
    Back to the topic, this waterproofing fix works well if done properly, like anything else.
    Fuquay Varina, NC
    Do you have exterior picture of this area? Any exterior issues you seen to associate with this area? Shrinkage cracks? differential movement? Inquiring minds would like to know...
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Raymond Wand,
    Mat speaks for himself, as he did on post 19.
    Apparently you missed it, his response to my post.
    The opinion that Mat is neither S nor S is my own.
    Your self-declared KISS level limitations and requirements for discussion are another story. You seem to be the only one that functions on a SS level.
    As far as your "flushing" activities, you may flush away to your heart's content. I care not what a simpleton does to entertain himself.
    Mark S. Connely's Avatar
    Mark S. Connely Guest
    There is another possibility that i have seen done occasionally you will get a bad poor line such as this when it is not properly vibrated and you will find not a crack but open gravel seams at the cold joint between the pours they may have used this as a repair to cover an ugly cold joint in any case the tabs could have been broken off and the wall painted to prevent this kind of discussion ... I personally like it when they dont try to hide it like this
